So the wifey overheated her 2001 QX4
had it towed home , and when I finally got the nerve to look under the hood I was pissed , they didn't even remove the lower intake ....
How can you tell if it's not the hose ?? Well we used mirrors the mechanic said
I got my tools out and removed the lower intake, IT WAS THE HOSE !!!! BUT
I or the mechanic working on my 2001 QX4 broke the terminal connection that goes to knock sensor , when removing the FI harness, it's attacached to that !!
I removed the sensor and am trying to figure out which wire goes to which terminal for when I reinstall ,
I cut back the insulation and I see what I think are a brown wire and a less brown wire (white originally ?)
but I am unsure of which goes on which terminal of the KS , any help would be appreciated. I have a pigtail on it's way but I need to know what wires go the which ( your photos may help) thank you in advance
HELP !!!
[/img]
