240sHorTy »
https://forums.nicoclub.com/240shorty-u28978.html
Wed Mar 15, 2006 8:08 pm
Test the knock sensor wire on the ECU harness. You should be seeing some voltage there if the sensor is at 564 KiloOhms. It is supposed to be between 2 and 3 volts when the engine is idling. If it is showing no voltage, you've got a wiring problem. If you are showing out of range voltage, that could be the sensor. I assume you already checked your grounds?
I don't know definitively, but I bypassed my knock sensor with a POT, and the correct voltage was acheived with a resistance somewhere in the 500 to 750 K ohm range IIRC.
The FSM is unclear of the 'correct' resistance, but the voltage at the ECU is given.
