Postby
92CA18Hatchback »
https://forums.nicoclub.com/92ca18hatchback-u18274.htmlFri Aug 13, 2004 1:14 pm
Anyone in here know where to get a knock sensor for the ca? Will the one from my ka work? Also, would this sensor being bad be a cuase fo my engine running EXTREMELY rich?
Postby
float_6969 »
https://forums.nicoclub.com/float-6969-u780.htmlFri Aug 13, 2004 1:14 pm
no, it won't make it run rich. And you'll have to get a knock sensor from a Pulsar that had the 1.6L. But like I said, I doubt it's the knock sensor making you run rich. The knock sensor has no effect on fuel, only timing.
Postby
T88lexus »
https://forums.nicoclub.com/t88lexus-u19328.htmlTue Oct 26, 2004 6:27 pm
yes bad knock sensor or bad connection/wiring on knock sensor will make the car run rich..knock sensor will retard the timming. which means that if there is a gas that cant be burned because of lack of timming.. yes it will be rich.
Postby
slw240sx »
https://forums.nicoclub.com/slw240sx-u528.htmlWed Oct 27, 2004 4:50 pm
wouldnt the more important questions be Did you wire up the knock sensor??? what makes you think its bad??? remember you have to wire the knock sensor up separate
float_6969 wrote:no, it won't make it run rich. And you'll have to get a knock sensor from a Pulsar that had the 1.6L. But like I said, I doubt it's the knock sensor making you run rich. The knock sensor has no effect on fuel, only timing.
