Yes, shielded wire. Are you familiar with coaxial cables? (Like, cable tv) Or RCA cables? The "ground" is usually a braided sheath that protects the signal wire from EMI, static, etc.
Mazza wrote:are more and more wires going to get old?
They're getting older by the minute. :P Certainly I wouldn't worry about changing the wire running to your horn, there are really just a few important ones - i.e. knock sensor, o2 sensor, CAS, etc. I wouldn't replace all of them unless they are visually worn are causing problems, though.
