dantesdoom »
https://forums.nicoclub.com/dantesdoom-u128282.html
Fri Jul 16, 2010 3:57 am
You can unplug the harness from the knock sensor...it has its own cable that comes up the backside of the motor (subharness). Your best bet would be to get a resistor (1 meg-ohm i think...but dont hold me to that) and put it on the connector from the wiring harness (car side) and pull the codes. If it clears up, its the knock sensor or subharness. If it persist, its on the wiring harness, in which case i would just rewire a new connector on...thats what i did and the problem cleared up. Otherwise just get a new sensor and harness and relocate to the back of the plenum.
