Big X2 on that, its there for a reason. If you want to bypass it just use the resistor trick.NismoChi wrote:The knock sensor is located there for a reason, it listen to the knocking (pinging), which happen in the combustion chamber, how can you find a place that is easy to get to but are close enough to the six combustion chamber that you have in your car? Relocating it to a different place, bad idea, IMO.
Modified by NismoChi at 10:39 PM 8/31/2006
I am interested to know about this as well. Please post a link to the thread if possible.yodawill2000 wrote:Gotta link to resistor trick ?couldnt find it via search
Wait a minute. You're ok with just bypassing it but not ok with relocating it? If you relocated it at least it would be doing something.DominickJ30 wrote:Big X2 on that, its there for a reason. If you want to bypass it just use the resistor trick.
Holy crap!!! Great find!! If it's good enuf for a 600hp monster, it's good enuf for my daily beater. Guess I'll be putting my car back together myself instead of paying someone to do it!!
The harness is part # 24078-30P00 and I bought it at my local dealership last week for $24.chingon77 wrote:Ok thats what i thought. I ordered the sensor and should get by the end of the week. I'm having trouble finding the sub-harness for it. It looks like there's only 2 wires needed so i figured i'll make my own damn harness with a little bit of cable, soldering, heat shrink and a little love. It would also keep excess wires to a minimum.I'll keep you guys posted.
Back in Ye Olden Dayes, when knock sensors began their ascent and we wrenchers were all proclaiming with glee the banishment of the air pump, it was a common engine bay trick to walk around to the back of a running engine hooked up to the Allen machine and while the endeavoring mechanic was all but deafened by the mighty roar of strangled power under the hood (where his head was, probably pondering why GM in all its glory had not only chosen to make the distributor hold-down bolt not only completely inaccessible without the special $60 Snap-On wrench that was fabricated by welding a long, incredibly-contorted rod onto a box end, but they had also chosen the remarkably bastard size of 16mm, which no wrench set had ever previously contained), we'd surreptitiously tap on the tailpipe with a wrench. This would make the knock sensor suddenly come to life and destroy whatever progress the poor blighter was on the verge of making in his tune-up endeavors.yodawill2000 wrote:Riddle me this .The sensor just fits snugg on the outside of the lower plenum ?Interesting..
It was cheaper at my local infiniti dealership.yodawill2000 wrote:Call Joe at everythinginfinti.com
I got a brand new ks off ebay for $60 including shipping and got the harness (1993) from my local infiniti dealer for $24.rdorman wrote:For the VE30DEhttp://www.4dsc.com/articles/d...shtml
Joe's prices:Knock sensor: $126.14 Ea.Harness: '90-'93: $96.25 ------- '94-'96: $31.59
