knock sensor
3.5altman
Car: 2002 Nissan Altima 3.5se
hey anybody know how to relocate a knock sensor a 03 3.5 max
maxhopper
Car: 02 Maxima SE 6spd
Why would you relocate it, and where are you relocating it to?
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
I've heard of this being done on fourth gens but haven't seen anything about doing this to fifth gens.
I thought the problem had been resolved...?
maxhopper
If you're going to hack it anyways, why not just install a resistor in line?
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Resistors tend to cause other problems, and can lead to knocking even with premium fuel. Most people go with a 470k ohm resistor, though. The relocated knock sensor is a good compromise between "faking it" and using the knock sensor. You still get some benefit, but you don't get the "false knock" that the stock location can sometimes cause.
That's my understanding, anyway. All I know is what I've read. I know this is much more common on VG33E and -ER Xterras using fourth gen Maxima knock sensor harnesses. The S/C Xterra people tend to prefer the relocation to the resisitor method, because the car can still turn back the boost if there's a problem. Obviously, this isn't an issue for the Maxima.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
why is it such a problem to just REPLACE the damn sensor and use it as nissan designed??
Be glad your cars only have 1 KS... VH45 has 2...
BTW you can find cheap ones on ebay usually NIB for about half the price of dealers... 22060-300P0 is the right part number and its the same for nearly every nissan.
3.5altman
ok well, where the hell is the knock sensor located? Anybody know?
maxhopper
It's going to be under the intake manifold/runners.
