So my knock sensor has fully taken a crap. Car has very laggy, flat spot between 2-3kHorrible gas mileage.
I did some research and found out that nissan knock sensor always crap out
I did found some article on using resistor ohms to trick out the ecu. Maxima requires 470k and xterra requires 570k ohms. I did not find an actual resistor to use for the sr20det. I have seen 500k, 600k. Also 1000k but no actual document.
So my question is what resistor should I used and how do I do it?Do I cut the wire pin27 (knock sensor) install a resistor and ground the other side?
I do not have money at the moment that is why I would like to use this method for the meanwhile.
