Knock Sensor Replacement
General discussion area for the L30-chassis Altima
240zdave
Car: 1971 Datsun 240Z (daily driver), 1973 Datsun 240Z (SCCA race car)
Is there a trick to removing and replacing the knock sensor? I've tried to reach it from under the car, but the steering rack, oil filter, subframe and I don't know what else is in the way. I can just get a box end wrench on the bolt, but have no leverage to turn the wrench. Is there a way to replace this thing without removing the intake manifold and coming down from the top? :rotflmao
240zdave
I forgot to mention that this is a 2000 Altima, if that makes a difference.
ItzNick Trash
Car: 1998 Nissan Altima GLE 2.4L 16v DOHC
Nope! I spent an ungodly miserable several hours playing contortionist from underneath to get it off initially only to find once that was done that getting the new one back on was absolutely impossible without removing a number of seriously time consuming parts (intake manifold is one way). However, if you just take the loose pigtail connector and tuck it up out of the way somewhere it won't set off your CEL after a reset. It will throw the code for it if you check em but like I said your CEL at least won't stay on.
Return to “2nd Generation Altima Sedan (1998-2001)”
