Question concerning a 92 240SX w/ KA24DE.
If the engine detects knock how much timing does it pull? If the ecu goes into a safe mode, will it reset itself after a length of time?
If knock is detected, will it show up as an engine code, or is that only if there is a problem with the sensor, wiring, or ecu?
Is it possible to bypass this sensor, even just temporary to see if this is what is causing timing retard?
