WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Sun Mar 28, 2004 8:49 am
If I Remember Correctly...no problem man. If your getting detonation loud enough to hear, your in rough shape. Buy a knock meter, I use the MSD knock meter, works like a champ. I'm not exactly sure how the ECU goes about retarding timing with knock, so I wouldn't use what I say as the example to go buy. There are alot of things that can induce detonation aside from lean A/F's. A bad thermostat can even give you troubles.
For a DIY knock meter, I have read somewhere on the net how to build your own. It was fairly simple.
WD
