knock sensor question
EvillE423
I searched but couldn't find what I was looking for. I hate the new search. Anyways, the clutch fan caught the wiring harness, unplugged a bunch of stuff. Ripped the plug off the MAF and fried it. Messed up the CAS too. I bought a new MAF and dizzy. My old plug wires were sticking and were starting to pull apart when I unplugged them. Bought some Accel wires. Before, I had the wires just spliced together on the old MAF and it wouldn't run worth a s*** and would smoke black smoke like no other. With all the new stuff on it, it no longer smokes and idles better, but still acts like its missing. I've still got a code for the knock sensor. If it was bad or unplugged, would it make it run like s***?
I'm in the process of buying a new wiring harness right now, so can't comment on the wiring yet. Although, I did pull all the insulation off of the wiring harness back to the #4 injector and don't see any broken wires unless the individual wire is broke under its insulation. Would a bad knock sensor make it run bad? When you first start it up, it idles fine, but the second you give it any gas, it starts running bad again. Also, what is the easiest way to access the knock sensor? I've felt around under the intake manifold, but can't reach it. Does it have to be taken off? Thanks!!
Justin35ll
Car: s13 coupe sr20det
Not sure on a Ka, but on my sr I can get to the sensor from underneith.
As for it not running correctly because of the sensor I'm not sure
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
it does run like garbage with the knock sensor busted, you can get to it by a long extension through the intake manifold runners. There is a thread somewhere.
EvillE423
I'll check both ways. Thanks you two
thomasjamal
Car: 93 coupe
EvillE423 wrote:I'll check both ways. Thanks you two
Yeah it's a pain to get to on the KA. I found one of those telescoping magnets really useful, and every extension I owned on for my ratchet.
dfddfd2
Car: 240sx
In the KA24DE bin, a bad/disconnected knock sensor will cause the timing to be retarded 6 degrees.
Dave
TimTurboZ
Car: 95 S14 w/RBXX... 65' Mustang GT
I'll sell ya one for $10 if you pay for shipping on top lol
EvillE423
TimTurboZ wrote:I'll sell ya one for $10 if you pay for shipping on top lol
I can get a new one for $23 bucks online so I'll just pay the extra and have a brand new one. Thanks though bro!
