knock sensor question....
c-rad
Car: 1991 Nissan 240SX w/CA18DET
Can you use the knock sensor from the KA24DE? Reason I ask is, the one that came on my motor is broken...literally. I COULD jb weld the green plastic tip back on, but I'd rather not be ghetto about it.
biosehnsucht
pretty sure you can't.
you can use one from the J30 maxima (08/88+ VG30E) or Z31 (08/87+ VG30T) or KN13 pulsar (09/86+ CA16DE / CA18DE) directly (matching part #'s)
I recall something about using a SR sensor if you rewireed your harness to work with its connector but I don't recall if that actually turned out to work or not...
float_6969
The problem with the KA-DE and SR knock sensors is that they are totally different. If you ever saw one, you'd understand. On the CA the actual sensor threads into the block. On the KA-DE and SR there is a bolt that threads in through the middle of the sensor and holds the sensor in that way. I've HEARD that the KA-DE/SR is a better knock sensor, but you'd have to rewire the harness. Not nessicarly major though either.
