mikeh16 »
https://forums.nicoclub.com/mikeh16-u19705.html
Thu Jan 27, 2005 6:06 pm
I searched and found the CA ECU pinout diagram on here a couple of days ago, andd it said that the knock sensor wire is on pin #23. I also read that all I would need to do is put a wire from the knock sensor straight to the #23 pin on the ECU.
So, yesterday, I tried it. My knock sensor wire was already cut in the engine bay, so I cut it near the ECU and soldered a new wire in. I ran it through the firewall and the the little bit of white wire that was on the knock sensor. When I went to start the car, it would not fire. It would turn over, but the LEDs on the ECU would no longer light up when I turned the key. Did I do something wrong? Is it possible that my ECU is wired differently?
Thanks,Mike
