TheOne »
https://forums.nicoclub.com/theone-u18820.html
Mon Mar 27, 2006 4:43 pm
ahhh.
ok i was wondering, i think am gettin some detonation(tho spark plugs don't show), it sounds like a bad throwout bearing, but it sounds in the exhaust(more like when a car is overheating and bein ran), but i can only hear it at part throttle under load, i can't/don't hear it with just revvin in neutral.
the problem is i can't seem to set the timing right because whenever i disconnect the tps, the car wont idle @ ~650-750(idles 1000+), i tried lowering it by adjusting the iaa valve(screw @ back of intake manifold), but that wouldn't help, the only other way would be by retarding the timing, whenever i connect the tps back on it idles fine.
i try setting the dist timing through setting the crank pulley to TDC, then settin the dist to the bigger of the 2 dots @ the end of it, then checking with a timing gun @ 20deg.
(sorry this should be on ka, not ka-t as i don't own a ka-t, but though about posting here first because it was about the knock sensor, maybe ka-t'ers would look at something about it)
