knock sensor problem
Winona
Car: 1990 240 sx
so i had some issues with my car not rnning rite... so i checked the codes... and got a 34 det sensor.... i checked the continuity and had nothing. os insetead of rewiring it all i just threw in a one megohm resistor between the #23 and 20 pins on the ecu. i drove it around the block reset the ecu and same thing still and same code also...i havnt checked continuety yet on the resistor cuz i dont have a multimeter with me today... any ideas? i checked the local auto stores and they diddnt even know what a knock sensor was or couldnt find one with the part numbr
capowered240
Car: 90 240sx
Just rewire it. Make sure you use shielded wire. that's about the only other thing you can do.
ca18datsun510
Car: bmw 330i zhp, 91 infiniti m30, 89 240sx, 07 zx6r, 05 trx450r
why did you put a resistor in?
do you know how a knock sensor works?
float_6969
Wire up the knock sensor, bypassing it w/the resistor isn't a very good idea. It's not hard to wire it up....
ca18det240hatch
sooo damn easy to wire....just snip it, and run a new wire inside to the knock sensor wire on the ecu (get a diagram at plxdevices.com)
Winona
Car: 1990 240 sx
alrite thanks just one more question if i hardwire to the ecu do i need the ground that wire?
ca18det240hatch
no, just wire it to that wire on the ecu. thats all
Winona
Car: 1990 240 sx
alrite thanks... sorry my car is in a garage and all im looking at is stuff online thats y my q's are sorta dumb rite now
