cyb3rneticvirus »
https://forums.nicoclub.com/cyb3rneticvirus-u145739.html
Fri May 31, 2013 9:49 pm
so i changed the knock sensor on my 93 ka24de, the sub-harness was missing the negative so i made one, after that i checked the voltage coming out of the main harness with the knock sensor unplugged , one ground and the sensor wire showing 1 volt with the car on engine off. i gone to another car that knock sensor works i checked his main harness both showing ground with the knock sensor unplugged. i can not find anywhere that says how much voltage should be going threw the cable with the car on engine off.people say with the engine on at idle it should show 3 volt i cant even turn my car on to even see whats the voltage. TLDR: what should be the knock sensors main harness voltage be with the knock sensor unplugged.
Thanks!
