knock sensor location sohc
obey
Car: s13
where is the knock sensor located on the sohc engine? is it the same location as the dohc engine? ive searched but nothing comes up specifically for the sohc engine and the sohc and dohc manifold look different.
nuts510
Car: sr20det 95 240sx, rb20det 93 240sx convertible, 78 280z turbo, 71 ca18det datsun 510, 72 scout,88 CR
you're not going to find a knock sensor the single cam car did not get a knock sensor. Why are you looking for it?
obey
Car: s13
my ecu threw the code 34 Detonation (Knock) sensor
onosqv
Car: '92 240sx Vert
sohc's don't have a code 34.
Either you have a DOHC or you read the # wrong: http://www.240sx.org/faq/articles/ecmcodes.htm
obey
Car: s13
really? i must be reading it wrong then.
ill check again tomorrow.
thanks for the info.
