Knock Sensor Location "Bank 1" P0325 OBDII Code
High_Octane
Car: 1996 Q45 Pearl White
The engine lights comes on for my 1996 Q45. When I check the OBDII code it is P0325, which indicates a failure with knock sensor "Bank 1". When I clear the code it comes back in 15 seconds, again and again.
Since I just have two knock sensors, which one is "Bank 1" ? Is it on the drivers side or passengers side of the vehicle?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Youll want to replace both of them, because the 2nd one is probably going to go soon.....
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Should throw a code for bank and sensor. 2nd one is after the catalytic converter and used for trimming.
High_Octane
I finally replaced the knock sensor on the driver's side. I am still getting the OBDII error message "P0325". I tested the knock sensor before putting it in, it measured 570K ohms.
Do I need to go to the ECM , find the wires and measure for a similar reading, in order to verify that the circuit isn't opened? I don't have the cars manual. Is there any easy way to find the wires?
What should I do next?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
maxnix wrote:Should throw a code for bank and sensor. 2nd one is after the catalytic converter and used for trimming.
Oooops, I thought we were talking about O2 sensors. Never mind.
High_Octane
I finally replaced the knock sensor on the driver's side. I am still getting the OBDII error message "P0325". I tested the knock sensor before putting it in, it measured 570K ohms. Do I need to go to the ECM , find the wires and measure for a similar reading, in order to verify that the circuit isn't opened? I don't have the cars manual. Is there any easy way to find the wires?
elwesso
2007 BMW M Coupe
Shoulda had you replace the harness while in there..... likely the cause.
FarFetched
Car: Suzuki SV1000S.
High_Octane wrote:I finally replaced the knock sensor on the driver's side. I am still getting the OBDII error message "P0325". I tested the knock sensor before putting it in, it measured 570K ohms. Do I need to go to the ECM , find the wires and measure for a similar reading, in order to verify that the circuit isn't opened? I don't have the cars manual. Is there any easy way to find the wires?
Erase the codes, check if DTC's (codes) come back!Cheers!
High_Octane
I have cleared the codes the the OBDII reader and the error message P0325 keeps coming back. I will try replacing the harness and the other knock sensor.
