mej30guy »
https://forums.nicoclub.com/mej30guy-u105785.html
Tue Sep 30, 2008 4:44 am
I have a 1995 J30 with a bad knock sensor. I have tried the resistor trick, and it worked like a charm. The car runs beautifully using this bypass. I have a new oem ks and factory wiring harness, but can't seem to get it to work properly.
Every time I connect it, the car runs like crap. Bogs down, high rpm, poor shifting, etc. I've tried to relocate it to several places on top of the engine, towards the back, with no luck. I did an ohm test last night and got 558 from the harness connected to the ks, and 557 from the ks itself.
I had the ks a little tight to begin with, but loosened it to just beyond hand tight without any success.
Any thoughts?
