Knock sensor issues. Need help
LEMHEAD16
Car: '12 Genesis Coupe
'95 QofDOOM
'56 Chevy pick up
Ok guys here is the deal. I had a knock sensor code. I checked the ohms on them at the harness. I could not get a reading on one and the other was around 210ohms so I assumed both were bad.
I got new knock sensors off Ebay and now I have a world of problems.
1.) With the new sensors installed I can't get a reading (at the harness) on either one. I have tested with key on and key off. If I put the old ones back in I still get the same readings (210)
I don't want to put everything back together until I am sure they new sensors are working.
Any ideas. I have searched the all the old posts concerning KS and haven't been able to figure it out.
Thanks in advance.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Whats the condition of the harness (New/Used)?
What year VH?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
you always want to replace the harness!!!!
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
I guess thats next on my list.
I didn't order it initially because it seemed fine. I get continuance (sp) through the wires with very low resistance. The out side sheathing of the harnees seems pretty backed but the wires inside seemed okay.
92 VH in an S13 chassis
Edit: Where are you guys getting parts from. My local Inf. dealer wanted $167 for the harness. I've seen some people talk about "Joe" where is he from?
Modified by LEMHEAD16 at 8:28 PM 8/14/2009
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
Joe Tesensky is the parts manager at IoS (Infiniti of Scottsdale). At 25% of MSRP, very hard to beat for OEM parts.
http://www.infinitipartsusa.com
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
eBAy = Great Unknown.
Did you test them be fore you installed them?
Did you test the old ones once they were out? What was their appearance?
Have you read the posts on KS replacement? New harness?
The word is continuity.
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
maxnix wrote:eBAy = Great Unknown.
Not sure how to test them out of the vehicle
Old ones are cracked and look pretty corroded
Yes I have read every post concerning knock sensors on NICO. I thought I might be able to get away with keeping the old harness since it tested OK. I plan on ordering the harness on Monday.
Yep thats the word I was looking for. I knew I was close
Q45tech
We don't want you head on to a semi at 80 mph passing and having a KS signal drop out from an intermitent KS or harness...........and suddenly losing 30HP.
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
makes sense
