Or, as long as you are always using 93 octane, just use the resistor bypass until you can relocate.gotspeed wrote:You're like asking the same question yes? But why are you waiting for the winter to be over before the relocation, it's very easy and quick, I posted pics here on where to place the new one. The knock sensor is causing you to use more gas than normal, so get that fixed and your gas problem should be over.
