Knock Sensor Damage???
dhkemp91
Car: '94 Nissan 300ZX NA
I am wondering if dropping a knock sensor from about waist high maybe a little higher on to a concrete floor will damage it?
I have my intake manifold(lower plenum) out and have direct access to the det sensor. I have removed the old one i just want to be sure the new one isnt damage and i didnt go through all the effort for nothing.
Thanks for the help!
es.biggs
Car: 1990 300ZX 5sp NA
I'd still put it in.
PAintballa45
Car: 1991 300zx n/a (TT in progress : D) slicktop
the actual sensors rarely fail, its the sub-harness that goes from the sensor to the efi harness that commonly fails.
dhkemp91
I tested the resistance between the pins on the sensor itself and it was just about .55 or .56. I've been trying to research and I think that's pretty common but if I could get someone to confirm my sensor is still good that would be great! And I also have a brand new subharness so I know that will be good.
es.biggs
According to the FSM if you have continuity then you are good.
dhkemp91
Ok then I should be good to go. Thanks!
