NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Tue Apr 18, 2006 6:10 pm
If your check engine light is intemittenly still flashing on accel you still have a misfire.A misfire as definined is the lack of combustion in one or more chambers.A lack of combustion can be caused by one of 3 thingsLack of sparkLack of fuelLack of compression
The last one would be constant and would not be intermitten.
This leaves you with 2 potential problems. Lack of spark or lack of fuel.
Spark is supplied by the plugs, wires,cap, rotor, and coil. The coil will only fire when the ECM tells it to, the ecm makes its decision to fire based off the crankangle sensor located in the bottom of the distributor. This sensor does not typically go bad unless it gets soaked with oil due to a bad seal along the sahft of the distributor. To see that area of the distributor you need to remove the rotor and the plate below the rotor. If you look in there and there is no oil, do not do anything else in there as that is likely not your problem.
Now for fuel you get fuel from the injector which gets fuel from the fuel line from the pump inside the fuel tank. The injector pulses fuel into the cyl when the ECM tells it to. The esm makes its decision to fire based on input from the crank angel sensor located in the distributor.
Typically when these distibutors fail the car flat out dies while driving. unless your having a die out problem I would not go after the distributor. The altima is known to suck the intake gasket at the #4 intake runner at the head. Though I have never seen the CEL flash when this happens.
My first instinct would be to check the ignition parts ,make sure they are nissan products and not after market garbage. The cap,rotor,wires and plugs should all be nissan OEM parts. They are basic ignition parts and should always stay OEM.
If that all checks out. Check for injector pulse with a noid light, check to make sure resistance is the same on all the injectors of a warm engine. Make sure you can hear them click.
