atraudes »
https://forums.nicoclub.com/atraudes-u214401.html
Mon Oct 12, 2015 7:29 pm
Kinda sounds like a misfire to me. You can test whether a cylinder is firing by pulling one spark plug wire at a time. If it stumbles or stalls, that spark plug is doing its job. If there's no difference, you found it. I'm not super familiar with the distributor systems on your car, but some part of the distributor (or maybe the spark plug wire or spark plug) is likely bad.
The fuel filter is probably worth looking at, but if that was the problem, it would simply fall on its face when you give it throttle. It would have to be REALLY clogged to cause the kind of problems you're describing, and would happen gradually over time. If the MAF sensor was bad, I'd expect it to throw a code.
The knock code is probably a direct result of the misfire. Once you get it squared away, one or more of the other problems will likely resolve themselves.
