90de4u »
https://forums.nicoclub.com/90de4u-u81477.html
Tue Dec 11, 2007 11:10 am
I'll try again and hit near the sensor and see what happens.
Also, I checked the voltage and ohm resistance on the TPS and everything was fine. I tried to adjust the TPS anyways, and even set it as low as .32 and it still idles high. Would the TPS cause a high idle like this even though everything is checking out OK? Car is idling at 1,500rpm when fully warmed up...when driven, stopped at a light, etc. Never any lower.
