jdurrty »
https://forums.nicoclub.com/jdurrty-u147989.html
Sat Jan 01, 2011 2:22 pm
I don't know exactly whats wrong with your car, but when I was getting a knock sensor code I soldered up some resistors to 550k ohms to trick the system and it has worked fine ever since. According to alldata the knock sensor should be "Approximately 500 - 620 K Ohms at 25°C (77°F)" so I went halfway with 550k. Hope this helps in some way shape or form with whatever you are doing.
