Lately my 95 has been bogging down and slowish in the 3K-3.5K RPM ranges, not always but it comes and goes. I can see on my wide band A/F gauge that as it happens my A/F ratio is really rich. Goes to about 11:1, sometimes on fwy if I let up on the throttle, it leans out as normal but then jumps back up to 11:1 without me giving it more fuel. Obviously something is. Also Iam getting a code 34, no CEL just the code. Ive read a lot about this but still don’t understand because of so many theories on how the system works. Please correct me (as im prob wrong) when the engine experiences a knock, it adds fuel and retards timing, but doesn’t throw a code cause that’s what its supposed to do. Ive read in numerous places that code 34 relates to a failed sensor, damaged harness or the shielding not being grounded out. I would like to add this 1M ohm resister I have read about for trouble shooting reasons. In the FSM it shows the white wire going from sensor, across pig tail to harness, then to ECU as you see in the pic the white wire is obvious, the second is the braided shield that is used to cancel out noise/interference, represented by cylindrical outline. If anybody can help, to tell me where and how they added this resistor, id appreciate it. I think it should be spliced in series with white wire, between F26 and 54/ECM but not sure. Is this done with all the plugs and sensor in place, or can I just pull off plug splice it in and not connect back to sensor side?
