InsanityInc »
https://forums.nicoclub.com/insanityinc-u19073.html
Tue Feb 07, 2006 3:23 pm
You can't bypass it. The knock sensor always "detects" knock by sending a voltage signal to the ECU depending on the output of it's piezoelectric device. Therefore, if the ECU gets no voltage, it assumes your knock sensor is busted, it doesn't check for an open circuit like most components.
