knock sensor bad ??
pungkiteater_671
ok i have a ka24de and every time i gun it it loses its power after 3.5 and the rpms just goes up but there is no power
also what are the symptoms of a bad knock sensor ?
sorry for the noobish question new to the nissan world
pungkiteater_671
cmon guys need advice before i go out and buy a 100$ sensor
midnightouge
Car: 91 Fastback
Have you even checked the ecu for codes? I installed a new one thinking it was the problem, but they rarely go bad.
pungkiteater_671
midnightouge wrote:Have you even checked the ecu for codes? I installed a new one thinking it was the problem, but they rarely go bad.
i got no check engine light
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
Knock sensor only needs to be replaced if the sensor is physically broken. The knock sensor is only there to detect a knock in the block. The knock wouldnt be created by the knock sensor, so the sensor is fine, there is something causing the knock. If you have no check engine light then I wonder why you have gone right for replacing the knock sensor?
By your description of the drivability issue, there isnt a person here that can be sure of why your car is doing what it is doing. Although, its obviously misfiring or your trans is slipping or clutch is slipping... Is the car auto or manual? How many miles?
I would give it a good tune up and check the compression. Chances are the plugs are fouled, the wires are junk, the cap and rotor are junk or the head gasket is bad. Also, check your timing, look for leaks and so forth. If it is manual and the rpms are rising and just feels like your going no where then you need a clutch, or the master or slave is on their way out. You need to be a lot more specific as to what your car is, the issues it is having and so forth. We have nothing to go on here...
midnightouge
Car: 91 Fastback
pungkiteater_671 wrote:i got no check engine light
Just because you don't have a check engine light, doesn't mean you don't have a few codes stored in the ecu.
