float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Sun May 12, 2013 5:38 am
How did he bypass it? You can't just remove/unplug it. If you do, the ECU pics that up, retards the timing, and throws a code. He had to have wired up a resistor somewhere. Usually it's done by the ECU. If that's the case, the car will run the way it sits. If you want to reverse that, then you need to remove that resistor and run new wiring (it needs to be shielded) from the ECU to the knock sensor location. You're also going to have to try to find a plug for the knock sensor and they are HARD to find. They're a very odd plug.
Good luck!
