knock sensor and injector failure
reptile28
Car: 1992 300zx 2+2
So my brother has a j30 and he came home and the car was overheating(ac blasting). Now it has a code 34 and 51. Im just wondering if im going to just have to replace the knock sensor and injectors.... or if there is something else that might have caused the knock sensor to go off that needs to be replaced as well
yodawill2000
Car: 94 Infiniti J30
Overheating will crack a old Knock sensor with a quickness.Shouldn't effect an injector unless it was REALLY hot.If that's the case I wouldn't trust that engine much.
coolyun_98
Car: 1993 J30 11,7000kM
Injectors/fuel rails on VG30DE (and many engines) are thermally insulated (rubber bushings) from the intake plenum.
reptile28
Car: 1992 300zx 2+2
well those are the codes that came up after the overheating....im pretty sure the injectors were never replaced prior to our owning the car
