goody90q45 »
https://forums.nicoclub.com/goody90q45-u31761.html
Fri Jul 31, 2009 1:15 pm
Before you throw in the towel go back a round or two and tell us how you decided you've got a bad KS. Likely scenarios are:
A) The mechanic pulled the ECU codes and one of them was the KS code. If this is the case you want to find another mechanic. The KS code purposely doesn't light up the CEL since it accompanies so many codes when an engine issue occurs. The code in these cases tells you that the KS is working properly. Or,
B) The KS resistance was measured with a digital volt meter directly at the connector, or even better on the KS pins themselves, and it showed an infinite reading or something much greater than 550k ohms resistance. If this is the case and the mechanic took the measurements then you're probably at the right shop.
Let us know which it is. You're probably going to get charged 6-8 hours labor to remove the intake to change KS but it can be done by someone with small hands (female mechanic, your proctologist) without removing the plenum, saving many labor hours. Many have done it. Do a search and print up the details to give to your mechanic and save a few bucks.
