-Fixed temp sensor issues by rewiring it. Reset ECU-Tested the ECU for codes w/ car off, Code 55 YAY!-Start car, revv it, check codes while running...55 YAY!-Take it around block. Bogging, crappy idle, etc-Check ECU with car running, Code 34
So here is my question: I have no downpipe, is there ANY way that could freak out the knock sensor at all? DP should be on as soon as I get the damn gasket in. I can't hear any "knocking" noise, so I am at a loss. Any ideas? I want my baby running perfect:(
