rsiwicki »
https://forums.nicoclub.com/rsiwicki-u13199.html
Thu Apr 15, 2004 11:02 am
Ahhhh I have the exact same problem that I have heard every now and then...but this morning on a test drive with the mechanic I asked him about it and he thought that it was the injectors also. Does this in any way hinder performance or indicate the injector is failing or about to fail? This is coming fromt the exact same place....rear passenger side and I can only hear it when under light acceleration from cruising at 70mph.
The dealer is currently looking into the timing, knock sensors, and a couple other things to determine if something else is causing it...but it only happens under a very specific set of circumstances.
