knock in ka24de
deft0ne
Car: '91 240sx SE (KA24DE)
theres a knock in my engine.sounds like it's coming from the top in the valve cover gasket.camshaft bearing?
180fan
Car: 89 fastback
check the chain guides.
deft0ne
iremoved the chain guides a long time ago...perhaps i have to tighten the tensioner???
it's not when idleing, it's when i step on the gasit's @ around 3000 rpms
Modified by deft0ne at 8:58 AM 6/2/2006
180fan
Car: 89 fastback
the tensioner is spring loaded. Are the guides on tight though? it could be bolts working their way out and rattling about. Or at least you should pray for that since it's simple and wont cause too much damage...
