cjparker1 wrote:when you take off the timing belt, do you have to do something else to reinstall or just put it back on?
After you take off the timing belt, you pull off the front plates behind the Camshaft Pulleys. Then you'll be able to take off the lower plenum. Re-assembly is the reverse of dis assembly.
I'm not sure exactly what you mean, but you need to compress the Timing Belt tensioner and line up the marks to put the belt back on.
cjparker1 wrote:Also, if I'm throwing that code...does it mean I need to replace the sensor...or can it be from faulty fuel spark, detonation...etc..???
This is a basic question for Automotive diagnosis and repair. The first thing I learnt when learning about ECU diagnostics is, that a faulty thrown code could mean that something else is wrong before hand but hasn't thrown a code yet.For example: A faulty O2 sensor showing lean with a trouble code could mean that the MAF sensor is bad because it's falsely sensing a shortage of air and the ECU is shortening Pulse Width of the injectors to compensate. So even though the MAF sensor is faulty, the O2 sensor sees an error.
In our (pre) OBD1 8-Bit ECU's, all error codes thrown are assuming the sensor is faulty other than the O2 sensors. It may or may not actually be faulty, but if you change a sensor to a good sensor and the problem is still there, then that means the problem is further upstream.
HellHamer wrote:ok i know what detenonation is too much air + not enough fuel = running lean/ big boom!
so what does a detonation sensor do?? sry i dont mean to pull away from the main topic
A detonation sensor is nothing more than a microphone that listens for supersonic or ultrasonic sounds and reports it back to the ECU in the form of Resistance. When a detonation occurs, a supersonic sound is heard by this sensor through the metal that it's mounted to. Similar to you putting a cup to a wooden wall and listening to someones conversation in the other room.
Cars, especially turbo cars, experience regular mild detonation all the time, and the job of the detonation sensor is to record the extreme sounds of detonations or the big detonations.
To the OP.If you are getting a Detonation sensor or Detonation Sensor subcircuit faulty code through your ECU (code 34), that does not mean your car is detonating.What's happening is your car is recording a constant, non changing detonation, which is impossible. The ECU knows it is impossible so it throws it into failsafe mode as a result.
