i think you are confused, knife edging a crank and removing the balance shafts are two completly diffrent thingsvboyq wrote:Hey everyone i was reading theMarch 2003 "Turbo" magazine and in it mentioned balance shaft removal for a QR25DE. Well anyway it says "... knife edged cranks are carved like a wing to better cut through the oil...less resistance means more power..."Does anyone know if it is a Balance shaft removal kit or a knife edge crank kit?? Also I assume it will work the same for the SR20DET, so anyone know where i can get one for the sr20? THANX!
