Big-Bird »
https://forums.nicoclub.com/big-bird-u44704.html
Sat Mar 03, 2007 3:48 am
Check your email. The emailed version has detailed links that you can click.
VG30iThe VG30i is a 3 L (2960 cc) engine produced from 1986 through 1989 and featured a throttle body fuel injection system. It has a long crank snout, a cylinder head temperature sensor positioned behind the timing belt cover, and a knock sensor in the cylinder valley.
Applications:
1986-1989 Hardbody Truck 1986-1989 Nissan Pathfinder
VG30EThe 3.0 L (2960 cc) VG30E produced 153 hp and 182 ft.lbf. Bore is 3.43 in (87 mm) and stroke is 3.27 in (83 mm). In 300ZX form, it produced 160hp and 174lb-ft. 1988 saw the 300ZX gain 5 more horses for a total of 165; however, torque ratings remained the same. In 1989, the Maxima received the 160hp rating, but also used a variable intake plenum that let it make 182lb-ft@3200rpm. Strangely, the 300ZX never received the variable intake plenum.
It was used in the following vehicles:
1984–1989 Nissan 300ZX/Nissan Fairlady Z 1987–1988 Nissan 200SX SE 1984–1994 Nissan Maxima 1990–1991 Infiniti M30/Nissan Leopard 1990–1996 Hardbody Truck 1990–1995 Nissan Pathfinder/Nissan Terrano 1992–1999 Nissan Gloria/Nissan Cedric (179 hp) 1992–1995 Nissan Quest/Mercury Villager (modified to become a non-interference design)
VG30ETThe 3.0 L (2960 cc) VG30ET was available in early production with a single Garrett T3 turbocharger and a 7.8:1 compression ratio. The USDM version produced 200 hp and 227 ft.lbf. In 1988 it changed to a single Garrett T25 turbocharger and an 8.3:1 compression ratio to reduce turbo lag, and was bumped to 205 hp and 227 ft.lbf. No VG30ET was ever factory equipped with an intercooler as they featured low boost pressure for fast response.
1984–1989 Nissan 300ZX Turbo 1984–1986 Nissan Fairlady Z Nissan Leopard Nissan Gloria/Nissan Cedric
VG30DEThe 3.0 L (2960 cc) VG30DE produces 222 hp and 198 ft.lbf. Bore is 3.43 in (87 mm) and stroke is 3.27 in (83 mm).
It is used in the following vehicles:
1990–1996 Nissan 300ZX 1987–1999 Nissan Fairlady Z 1988 Nissan 200zx (similar chassis to the 300zx, different panels 1993–1998 Infiniti J30 and Nissan Leopard J. Ferie 1992–1995 Nissan Gloria and Cedric 1989–1991 Nissan Cima
VG30DETThe VG30DET is the same as the VG30DE, but with a single ceramic turbo. It produces 255 hp. It was used in the Nissan Leopard (F31)
As well as the Nissan Cima, Gloria, Cedric (y31).
VG30DETTThe 3.0 L (2960 cc) VG30DETT produces 280 hp and 283 ft.lbf when mated with a 4 speed automatic transmission. When used with a 5spd manual transmission, it was rated at 300hp and 283tq. It featured twin T25 turbochargers, twin intercoolers and variable valve timing.
1990–1996 Nissan 300ZX Twin Turbo 1990–1999 Nissan Fairlady Z Twin Turbo
VG33EThe VG33E is a 3.3 L (3275 cc) version built in Smyrna, TN. Bore is 91.5 mm and stroke is 83 mm. Output is 180 hp (134 kW) at 4800 RPM with 202 ft.lbf (274 Nm) of torque at 2800 RPM. It has a cast iron engine block and aluminum SOHC cylinder heads. It uses SFI fuel injection, has 2 valves per cylinder with roller followers and features forged steel connecting rods, a one-piece cast camshaft, and a cast aluminum intake manifold.
1996–1999 Nissan Pathfinder 2000–2004 Nissan Frontier 2000–2004 Nissan Xterra 1998–2004 Nissan Elgrand 1999–2002 Nissan Quest/Mercury Villager
VG33ERThe 3.3 L (3275 cc) VG33ER or VG33S is supercharged and produces 210 hp (157 kW) at 4800 RPM with 246 ft.lbf (334 Nm) of torque at 2800 RPM.
2001–2004 Nissan Frontier SC 2001–2004 Nissan Xterra SC
NOTE: The 4.0L was left out of this list.
