kinda shakey
mattynicks3
Car: 2000 Nissan Maxima SE
my 2000 maxima shakes sometimes while driving. i can feel it mostly in the steering wheel. could this be something as simple as an improperly balanced tire? i thought it could be but at the same time if a tire was imbalanced i figured it would shake all the time. sometimesit feels worse than other times. ideas?
tigersharkdude
Car: 1999 Nissan Maxima
if it gets worse the faster you go it could be something in the lines of you needing rotate and balance or an alignment
mattynicks3
yea thats what i thought. but sometimes it doesnt even shake/vibrate at all. its weird. ill probly have the tires balanced anyways just to see if it fixes the problem
STHOMSON
Car: 1996 Maxima
Unlikely to be alignment related unless you have a severely worn part. The "not always" condition would lean a little to suspect inner cv joint wear and / or wheel balance , out of round tire(s) . Cv joint if over 100k miles or has had a "hard life" . Balance can get in & out " of sync " by turning corners .
