ddgsxr504 wrote:245/45 is actually .1 inch smaller tire diameter compared to stock, but then again I don't know what you used for my stock set up. For me it was originally 205/55/16.
Not true. You are doing your calculations wrong. I used 205/55/16. 245/45/17 is taller than stock.
ddgsxr504 wrote:a 3.16% change in speedo accuracy equates to about 1.8-2.0 mph off which you are correct in concluding that it's not much to even worry about.
Haha no offence, but how the hell did you equate a percentage to a number without using a second number to take a percentage of.
A correct statement would be: "That only equates to 3.16mph at 100 mph, which is not much to worry about."
Different diameter tires will make the speedo a percent off from the factory, meaning if it is off 5mph at 50, it will be off 10mph at 100. It's not gonna be off a constant number throughout all speeds.
Good luck with your tire choices by the way. Finding tires you like in staggered sizes is never an easy task.
