kind of new in the 240sx world and car has issues
madscientist3105
Car: 89 240sx coupe
ok heres the deal i just bought an 89 240sx from a neighbor. the car sat for like 2 years because it stoped running right and he took it to a shop and they told him the cat was bad.ok so i bought it for 500.the car didnt go over 2500 rpm and thats if you where really babying the car.if you pushed down on the gas pedal it would bog and die.so i figured it was the cat.so i gutted it.now it goes to like 4700 then falls on its face and only if you baby it.i just wanna get it running right before i put the new motor in because if that problem is still there i dont wanna have to chase all the problems at once.
AmoebAssassin
Car: 1991 Base fastback 5spd, black
Is it like you're hitting a fuel or spark cut at 2500 or 4700 EXACTLY, or is it that that's just where it happens to happen +/- a few hundred rpm?
themadscientist
madscientist3105?ahem.
Rex
Car: None
themadscientist wrote:madscientist3105?ahem.
You're being cloned, you'll have to add themadscientist_THAT_themadscientist .
themadscientist
I wonder if his mother and I have met. that would him one ugly kid though, for his sake I hope not!
Trying to run it with a melted cat may have done some damage. Do a compression check on it, if everything reads right give it tuneup; cap and rotor, plugs, air filter, oil change and reset the computer and see what that does for you. Even if the motor is a loss $500.00 aint a bad deal if the body is in good condition.
madscientist3105
Car: 89 240sx coupe
well it was 2500 til i gutted the cat which i figured was cloged.now its at 4700.any ideas.i apologize to themadscientist i picked the number cause thats my sn on all my other website/forums and the numbers are the same my sons b-day
themadscientist
I don't care man, I'm just yanking your chain. You obviously have good taste in screen names
madscientist3105
Car: 89 240sx coupe
i just did the tune up it cleaned up a little bit but its still pretty bad. i did the plugs wires cap.the rotor i got was wrong.im gonna do the fuel filter and add a ton of gas.
madscientist3105
Car: 89 240sx coupe
the body aint that great either but i have another motor with 30,000 miles on it i picked up for 150 with a stage 3 clutch
madscientist3105
Car: 89 240sx coupe
did the fuel filter too.still doing it.im going to do a compression test this week any help in the meantime would be great
240DRFT
check the compression if its bad then go swap in the other motor u got.if its good comp i dont really know...still swap it
slc240sxse
Car: 96' 240sx SE
Drop your downpipe off of your exhaust manifold, fire it up and see how it goes from there. Sure it will be loud, but it will give you an idea. Just hope it is'nt running rich, I'd hate to see you go up in flames.
madscientist3105
Car: 89 240sx coupe
i already gutted the cat
