Are there any advantages to doing this? (bypassing the clutch) Other than requiring one less step to start the car...neverlift wrote:disable your ignition system 50 keys wont start it. The clutch switch could easily be bypassed with a wire. I start mine with no clutch all the time.
The fuel pump kill switch is the most tried and used method on Honda-Tech. Where in the bay are you going to kill the battery and alternator which wouldnt be obvious?SPIRONIUM wrote:why not just a battery/alternator kill switch
I just did an install on a Scion which has a hidden fuel pump kill switch located where the ebrake handle is and a starter ground connected to the seat belt sensor. No seat belt on no start signal....SPIRONIUM wrote:I mean, if somebody really wanted to steal your car it would be gone no matter how many kill switches you have in your car. Fuel switch under the dash is obvious i think or any switches like that unless they are very well hidden in a strange spot. if you get a battery/alt disconnect you can get one with a removable key. So if the key isnt in there, it could still be in plain sight and still be a good deterant because the thief would have to connect those wires with some tools.
