Kill Switch Suggestions....
SoCalS14
Car: My car...duh
OK...So I am dumping a good amount of money into my 240...and I would like to be the only one to benefit from this...catch my drift? Or do I have to snow again?
Anyhow...I would like to wire something up inside the cabin, but am unfamiliar with how the ignition wiring is routed/works....
Has anyone wired one?
Does anyone have a particular "wire" that would be a good candidate for a switch?
Does the AMP rating of the switch matter?
getnrowdy23
Car: '95 sr20det 240sx se/2004 suzuki sv650s
call your local nissan dealer if no one else posts here... just a thought and a bump
RalphCare
as soon as i find the kill switch diagrams i have, i will post them.
i know u must use a relay if you want to prevent burned wire fires.
prior
http://www.autospeed.com/cms/a...9&P=1
there's a link to the one im putting in my car. just choose which circuit you want to hook it into (fuel pump, ignition, etc...) and your good to go.
NecCo
Car: Computer Science
I am a fool.
editted! for ignorance
SoCalS14
Car: My car...duh
Seems sorta compicated, but not too hard...the magnet deal is very cool...
Nismo_Freak
Car: 89 Nissan 240SX
Just run a switch for your fuel pump.
SoCalS14
Car: My car...duh
ok...that is an idea, its just they will get the car started and down the street...
xns
Car: Computers and cars
Ok, so I got all the pieces to that DIY, looks pretty cool, I wired it up and it works real good, just get an FSM that floating around the boards for the 200sx and find the ignition wire that waybtw: you can cut anything with the first relay, from the fuel pump to the ignition wire (most effective)
SoCalS14
Car: My car...duh
So you go it to work eh? Thats cool because I liked the "trickiness" of that design...where did you place the magnet?
xns
Right in the center console. Locational wise, it will be by the place where I put my seatbelt in, that way, as I move to insert the belt, I'll swipe the magnet.
SoCalS14
Car: My car...duh
Not where you placed the reed switch...thats suppose to be a secret! I meant the magent to activate it, did you place it in a key fob of some kind?
xns
Whoops, lol, the magnet, hmmm, I got this little keychain thing that was used for a car promotional thing, where you take the keychain, (which looks like a car alarm thingy), and try and unlock the car. SO I just took that apart and am currently in the process of making it fit a magnet. But for now I just use the magnet that came with the reed switch. kinda wierd to have a big white thing chillin with your keys though...:cool:
SoCalS14
Car: My car...duh
I was thinking about just putting the magnet in the glove box. Its not like a theif will know what it is for?
marshun
the magnet switch is interesting.
but you can splice the wires that put your car into the "on" position. this will kill spark and fuel.q
xns
thats what Im doin :D
SoCalS14
Car: My car...duh
XNS....Man I am having trouble with that diagram...I am not a electrical kinda guy...The DPDT switch I bought has eight prongs...but the drawing only looks like 6...do you ahve a better drawing or a picture that could see? only the wiring for the DPDT switch
xns
yeah, lemme just go crazy with asiic for one day and I'll have it for ya
btw I take it you bought this DPDT relay from radioshack?
SoCalS14
Car: My car...duh
Yup...it has eight terminals....6 lined up one-way...and two at the top.
driftin8ez
Car: 92 Coupe, Turbo Miata
i just recently wired one of these up. It was pretty tricky. That diagram didn't help me. I just bought all the stuff from radio shack. The twoo that go the other way are power. Connect power to the + side and wire the reed relay as the ground. So when you swipe the magnet it completes the circuit and "pulls in the relay" This will cut power to the led and reroute power to "pull in" the second relay alowing your car to start. You also wire the always closed push switch as the ground on the second circuit. So when you push the button it will cut power to relay dropping it from the "pulled in" position and supplying power to the led.Hope that helps. I would take pics of mine but i have it hidden and taped into my wire loom so it would be impossible to take out without screwing it up.
SoCalS14
Car: My car...duh
Thanks man...so I take it you only deal with the "6" prongs that line up right?
driftin8ez
well the 6 prongs that line up are going to be related to sending power to different circuits.
SoCalS14
Car: My car...duh
OK....so I take it you use all 8 prongs. I think I can do this, although a better diagram would be helpful.
hybrid_flyer
Car: 95 240sx SE wrecked....89 240 coupe now
wow, the reed and magnet is definitly a creative idea. I had a honda that I installed a kill switch in. Basically I just used a 5-pin relay and a single throw switch, and just hid the switch. The wiring was done to the KO position on the column. Worked great all I had to do was find a hard to find spot on the car for the switch.
Zydeco
Car: The poster formerly know as -]sTm[-HeavyHips
just take your coil wire.
wangless
Car: '02 MBP WRX
^ LOL, thatll definitely work
SoCalS14
Car: My car...duh
Great advice, but does an SR have one?
wangless
Car: '02 MBP WRX
take out the ignitor chip or coil packs LOL
SoCalS14
Car: My car...duh
I didn't think so.
wangless
Car: '02 MBP WRX
