Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Tue May 27, 2008 10:03 am
If you made it to be an anti-theft kill switch, I wouldn't have made it look so obvious. I maen, it's a red switch that looks like a racing kill switch, plastered on a black backing. That style of kill switch is meant for racing so if you have engine trouble, someone outside the car can easily turn your car off to keep it from causing more damage than necessary.
Also, for that purpose it needs to be up and in plain view. Easily identifiable. Most cars I see in SCCA sanctioned events have it on the hood.
If you want an anti-theft kill switch, do an ignition kill switch hidden somewhere in the cabin. There's been a lot of talk of using magentic reed switches to do just that. And to keep the kill switch from cooking my radio presets, I would do it up as an ECU cutoff. Preferably cut the power in, or the grounds out, of the ECU. It wouldn't be hard to set one up to cut the switched power to the EGI relay. The red/black wire that runs from the ECU to the EGI relay would be the perfect line to break as it isn't a high current line and it controls the EGI relay selenoid.
