maxentropy wrote:Dayumn! Nice install boss. Really want to hear your system in person! Too bad you are on the other side of the good ole' usa...
You need to get yourself a racingline battery tie down!
The factory tie down actually works perfectly.. very secure, which is VERY IMPORTANT because of the metal brace sticking out whee the factory battery was braced. I couldn't use this due to the location of the positive terminal on the HC1800
LongBeachCoupe wrote:Holy wires batman!I never thought id see "high voltage" in a coupe engine bay...
Doc, whyd you leave the hood damper brackets silver... no paint?
Its amazing how many wires there are to make everything work right and perform to spec...
Nice work!
the stock brakets look ok to me for now... I wish i had the free time to attack small details like that... but no go
Also, as I mentioned in a previous thread, I plan on removing the factory distribution block, and attaching an aftermarket distribution block with midi fuses... the problem Im running into is the fact that I'll have too many large wires to connect, and not enough llarger gaugse outputs on the battery terminals
