PoorManQ45 »
https://forums.nicoclub.com/poormanq45-u17729.html
Mon Feb 13, 2006 3:54 am
I would not recommend doing this.
Tweeters, more specifically, high frequencies are highly directional, and are easily reflected/absorbed. So, when you're driving the car your left leg is going to block the tweeter, and thus cause the highs to be very muffled from the left speaker.
If anything I'd recommend that you place the tweeters up high. The most common places are the sail panel, or the a-pillar.
Beware though, if you do this you highs are going to be extremely overpowering, and should get a little bit of time correction, but that's not neccesary.
If you just want cleaer highs, go ahead and mount the tweeters where I suggested
