Hmm. Well, that sub is available as either a dual 2-ohm or dual 4-ohm configuration. If you pick up two dual 4-ohm subs, you can wire each to a 2-ohm load, and run them parallel to have the amp see 1-ohm overall. That amp is stable to one ohm, and will push 1000 watts at that impedance (actually, maybe a touch more cause it will probably be slightly underrated - you'd have to check the birth sheet). The subs can handle 600 watts each, so that should be acceptable. Make sure the gains are set correctly, and you can probably push a little over 500 watts RMS to each sub.dnasty88 wrote:im thinking about getting 2 10 inch l7s with a rockford fosgate T10001bd. is this going to be enough to push these subs? i know the rms is a little low but would that be a problem?
also if i bought any of these items factory renewed, with 90 day warranty...would i have a prob you think?
Applebonker, you know to leave the Rockford questions to meAppleBonker wrote:
If you get them respiffied, you should be ok. If they function out of the box, you should be fine. If not, the warranty will take care of this. Pushing the amp too hard will fry the subs (if you push the amp to clipping you can easily blow the subs with less power than they can handle). If this happens after 90 days, you'll be SOL. However, you could easily blow brand new subs the exact same way. If you can get a deal on them factory renewed, you shouldn't be worried about this. Again, the gain setting is the most important part in ensuring your investment lasts!
Haha. Busted! Yeah, I guess I'd listen to Doc here on this one. Pretty sure he knows the ins and outs of RF better than I do (ok, completely sure). Point is, that should pound well. If the amp is going to run better at 2 ohms, and still push that much power, two dual 2-ohm impedance subs would then be ideal. Doc, you win.rjdmmfl1 wrote:
Its all good, RF products can be difficult to gauge going by their released specs alone... its like the GT-R, they underrated everything in terms of specs released...AppleBonker wrote:
Ha. If I ever win the lottery and come into a bunch of money, I've always said this is something I would do. I'd love to open up a home/mobile A/V store and sell and install this equipment. I waste nearly all of my free time researching products and trying to test them out. Man is this an expensive hobby. I'd probably also open up a gym. If I had those two locations, I think I could work nearly 18 hours every day and be a very happy man.Rellz CT wrote:apple and doc
are u guys audio salesmen?
if not
you definitely should be
I have never and would never run subs down to 1 ohm... its a sure fire way to blow them eventually... also, as mentioned, the bass is not as clean as running @ 2 ohms...dnasty88 wrote:aight so i talked to my brother who is heavy in to car audio and he ntold me to do what apple bonker told me to do...how much off a difference will i see if i go with the 2ohm woofers vs the 4ohm and the different install scenarios
Applebonker has a VERY GOOD tutorial about gain setting and "proper gain setting" on his FAQ at the top of the A/V forum. He can get away with a .75 ohm load because he properly sets his gains, the average person thinks the gain is a bass boost and that is not correct.dnasty88 wrote:lol i was always told theres no such thing as a stupid question. you keep refering to gains..are you talking about the dials on the am itself. or the wired remote that comes with it, or both?
this is where applebonker and I differ a bit... I would suggest you connect the remote bass knob, and adjust your gain with the knob turned up to the loudest you would ever want the bass... by doing this, you properly set the gain at the correct voltage, and won't ever get more than this, however, when a nice jazz song comes on, or an R&B, or soft rock song is playing, you can turn the bass down, and just hear the music...sometimes, bass isn't a good thing for certain genres of music... just my .03AppleBonker wrote:In the gain setting tutorial, I didn't mention an bass control knobs like you are referencing. My amp that is running to the sub has one of these as well. I didn't even connect mine, and I would recommend you do the same. I'm pretty sure all aftermarket head units have the ability to adjust at least the bass, so I would use this over a knob. If you set the gains with the knob turned halfway up, you could easily damage equipment if the level on the knob is turned up any more. It's far easier to just leave it out.
