Turbogst »
https://forums.nicoclub.com/turbogst-u138770.html
Wed Jul 29, 2009 6:07 pm
Lets make an example. Most subwoofers are rated with a thermal power rating. Now, say you hook up a subwoofer that is rated for 800 watts thermally, to an amplifier that is putting out 600 watts rms. Now, when the amplifier is properly adjusted (depending on the quality of the amp, of course), it will probably put out around 600 watts rms.
Now, when the gains and/or bass boost is turn up higher, it will send the amplifier into what is called 'clipping'. What clipping is, is exactly that - a clipped sine wave. When an amplifier starts to clip a sine wave, it starts to put out much more power than it was before, and these higher power levels, capped with the flat tops of the sine waves, are what cook speaker's voice coils. When the flat top of the sine wave is being played by the speaker, the speaker is not moving (you probably can't see it, we're talking ms here), therefore there is no cooling of the voicecoil. This leads to heat buildup, and later leads to voicecoil failure due to overheating it.
So yes a underpowered amp , would amplify distortion because you have to turn the gain up and the volume way up to be loud. Lower the volume with more power is cleaner.
Ps I have put together many SQ and SPL systems I didn't pull this out of my a**.
Modified by Turbogst at 9:15 PM 7/29/2009
Modified by Turbogst at 9:16 PM 7/29/2009
