kick down switch?
mattlikesinfiniti
Car: 1996 Infiniti J30
the guy with the j who got beat by an mx6 said the j had a kick down switch? ive never heard of it, can anyone tell me what it is/where to find it?
thanks,matt
gr8scott72
Car: 1994 Infiniti J30t
mattlikesinfiniti wrote:the guy with the j who got beat by an mx6 said the j had a kick down switch? ive never heard of it, can anyone tell me what it is/where to find it?
thanks,matt
It's called a gas pedal.
mattlikesinfiniti
oh man, i feel like an idiot now, guess i gotta get used to this forum lingo or somethin i dunnothanks for the reply though man
yodawill2000
Car: 94 Infiniti J30
Sure threw me off to . didnt say anything though .
"i know that the j has a kick down switch which sets the engine and transmission to race mode which i use every now and then"
mattlikesinfiniti
hah yeah man
95-J30tt
Car: 95 Infiniti J30tt (Twin Turbo)
Hi i'm the one who got beat by an MX6....... i did mean a kick down switch, i have a 1995 j30t "canadian model", and when you press the accelerator all the way down you would hear a switch that engages in the last 1cm of a full pedal press, it gives the engine "injectors and so on" and the transmission a different programming, try it out, it is fun, i use it every now and then. it is not explained much in the service manual, but if you have a shop service manual, you will find a brief explination there. i'll try to post the page, i dont have a scanner but i'll take a photo of the page and post it this week.
yodawill2000
sweet ..Wish I had that ..
DominickJ30
Car: 1993 Infiniti J30t
lol, that is called a WOT(wide open throttle) switch.
Every car has one.
95-J30tt
i'm not sure what is it called but it makes one heck of a difference when needing power from the engine, although i'm pretty confident about the program setting for the engine, i will double check, and take the photo of the page and post it sorry if i misslead anyone as i'm not sure about the name of the switch
95-J30tt
ok i took some pics of the page with the pedal components and here they are
95-J30tt
95-J30tt
ok, so it is a Kick Down Switch after all, i starting doubting myself, anyways..... i'll be working to change the tie rod tomorrow "not sure if i mensioned that in this thread" , i'll take some pics of the procedure and the part number and the brand of tie rod tomorrow...... till then, thanks for keeping this forum alive
yodawill2000
The tension rod is easy to do ..Be sure and torque the main bolt with the load applied to the wheel !!
I used a block as I dont have a ramp.
DominickJ30
Some call it a kickdown switch, some call it a throttle switch, some call it a wide open throttle switch.
Elisha
Car: Infiniti J30
is this available on the 93 J30s?
if so i'm gonna step on it today to see if it works.
driverdriver
Car: NICO's longtime resident Canuck!!!
Elisha wrote:is this available on the 93 J30s?
Yes
DominickJ30
You will probably hear a slight click when you really punch it from a roll.
praxis469
Car: 1995 J30
I also believe that the "kick down switch" is also directly tied into the fuel gauge. When the "kick down switch" is activated it causes the fuel gauge to drop towards the "E" mark at a faster rate!
95-J30tt
speed comes at a price........ but at least it is available........
gr8scott72
I drove the J to work today and played around with it alittle. I can hear the switch click when I push it all the way in. The difference in acceleration from just before it clicks to when it clicks is not very much and I don't think the transmission is connected to that switch as it would "kick down" long before I got to the point that it would click.
My guess is that it just changes the ecu mapping and puts it on a preset program that increases the amount of fuel injected to the maximum amount possible. (along with changing the a/f ratio, etc, etc.)
DominickJ30
gr8scott72 wrote:My guess is that it just changes the ecu mapping and puts it on a preset program that increases the amount of fuel injected to the maximum amount possible. (along with changing the a/f ratio, etc, etc.)
It does, along with raising transmission pressures. And of course effecting at what RPM it shifts.
The "kick down switch" is simply tied to the throttle position sensor, to give maximum possible voltage to the ecu when you demand it.
